Wall properties
Edit the parameters of selected walls and their components, as well as curtain walls, from the Object Info palette. To change the wall attributes, use the Attributes palette. Certain parameters are available for standard walls or for curtain walls only. Settings on the Render tab are not available for curtain walls, since the textures of frames and panels are specified separately. Use the Edit Curtain Wall tool to adjust the frames and panels of curtain walls.
The fields in the Object Info palette are named similarly (but not always identically) to those in the Wall Preferences dialog box, and roughly reflect the order in which settings are entered in the dialog box, for ease of editing.
The wall parameters are described in Preferencias de pared estándar and Preferencias de muro cortina. Only the parameters that are different are described here.
Parameter |
Description |
Style |
Displays the current wall style. You can convert the wall to unstyled or see Reemplazo de estilos de pared en la paleta Información del objeto or Edición de estilos de pared. |
Vis Thick |
Displays the visible wall thickness, while accounting for component visibility settings. Invisible components on the interior and exterior of the wall cause the wall to appear thinner than its actual thickness, for display purposes. |
Components (standard wall only) |
Opens the Wall Components dialog box. For unstyled walls, edits the wall components; for styled walls, edits only the Component Top and Component Bottom settings to customize heights of individual wall components (see Creación de componentes de pared) |
Curtain Wall Grid (curtain wall only) |
Opens the Curtain Wall Grid dialog box, for editing the curtain wall frame and panel settings as described in Preferencias de muro cortina |
Reverse Sides |
Reverses the direction of the wall sections (see Dirección de paredes); walls should be drawn in a clockwise direction |
